330u ??'s
Tweeter
04-15-2006 19:49:17
Been using my 330U a lot now and I notice that the throttle lever has to be half way before the engine even revs up from idle. Is that typical on these Utilities or do I have some adjusting to do?
When the tractor is in 4th gear and I drive down hill, the tractor feels like it is in neutral and not in gear but when the ground levels out, the tractor is still in 4th gear but goes slower. Why? Shouldnt 4th gear show some resistance at some point?
Janicholson
04-16-2006 17:11:43
 Re: 330u ??'s in reply to Tweeter, 04-15-2006 19:49:17
The throttle linkage does wear. With it turned off, and the throttle dash lever at full forward idle, find the governor control lever on the back of the gov. Remove the link from the control lever. Now move the dash lever to full throttle (last notch). Go to the governor again and see if the link is long enough to be pushing the governor control lever to full travel (align the link with the hole and see if it went as far as above. If it did not, adjust the length on the link (you may need to remove sheet metal to get at the assembly to adjust it) There are two springs and a metal bracket. Study it so that when adjusted it remains in the same tension, but moves the link as needed. If a spring is broken, replace it with a simslar hardware store spring. (they do not change the engine speed, that is inside the governor).
There will be a dead zone (about 1/4-1/3 of travel at the Idle end. The above makes sure you are able to apply ful throttle.
If the TA lever is pulled back and latched, and the tractor slows down about 30% but still pulls, the TA is probably OK. IF it stops with the TA pulled back, The TA is out. It should not free wheel in direct drive. If the lever does nothing, the linkage may be broken, or way out of adj. The tractor may not be going into direct at all. If it will go only about 12-13 MPH in fifth gear it is not in direct, and needs attention to the linkage at least. A manual is a must.
JimN Keep us informed.
Dave Slater
04-16-2006 13:44:30
If it speeds up down hill and the engine is not speeding up as the tractor does,I would suspect the T/A clutch is slipping. It should slow down to low T/A under load also if thats happening.
CNKS
04-16-2006 10:26:56
"When the tractor is in 4th gear and I drive down hill, the tractor feels like it is in neutral and not in gear but when the ground levels out, the tractor is still in 4th gear but goes slower."
All tractors and cars will do that. You can retard the throttle and get engine braking. But, if you go down a steep incline, it will still speed up.
PAULIH300
04-15-2006 19:54:36
Those throttles develop wear over time...say 50 years or so...and thats usually what happens,they will idle down,but to throttle up,takes more than would normally be required.
Do you have TA engaged? It freewheels when coasting.Never use TA going down a hill,always downshift to a lower gear.
Tweeter
04-15-2006 20:39:17
 Re: 330u ??'s in reply to PAULIH300, 04-15-2006 19:54:36
Can I adjust the throttle linkage?
The T/A lever is forward. Is that engaged or disengaged?
Dellbertt
04-16-2006 06:29:17
 Re: 330u ??'s in reply to Tweeter, 04-15-2006 20:39:17
TA lever forward is disengaged.
Pull the lever back toward you is engaging the TA.
The tractor goes slower when engaging TA in any given gear.
