farmall H still wont start
jdo
04-16-2006 16:56:55
Had family mechanic look at carb seemed to be working fine. have a mag ignition he thinks timing is off 180 degrees is that posibble because it does not back fire when sprayed with starting fluid. should i change from mag ignition to a battery ignition. thanks for the help
dej(JED)
04-17-2006 09:49:43
 Re: farmall H still wont start in reply to jdo, 04-16-2006 16:56:55
There are only 3 other positions that the mag can be in. Remove the 2 bolts and pull the mag out to where you can roll it over one step at a time. If it is hot it should fire within the next three settiings.
Nat 2
04-17-2006 07:05:27
If the mag has been checked, and works, then why is changing over to battery ignition even a consideration?
Just get everything put back together correctly, and the tractor will start. There's no magic to it. Air, fuel, and fire at the right time, and BANG! off she goes.
Brownie 45
04-17-2006 05:45:33
Is spark getting to the plugs? If you have spark from the mag to the distributor cap & none to the plugs, check for problems in the distributor cap, rotor , & don't overlook the carbon contact & spring in the center of the inside of the cap. Otherwise, check that the rotor is "pointing at" the proper sparkplug terminal in the dist, cap when that sparkplug is about to fire.
MagMan
04-16-2006 17:33:53
If you think the mag is 180 just switch the plug wire on the cap 180 and if it is it will run. JON
Charlie M
04-16-2006 17:04:33
If you've had the mag off its possible its 180 degrees off. To find out, remove the spark plugs and put you finger in the hold to plug it. As you turn the engine over by hand when the piston comes up on the compression stroke it will blow past your finger. Shine a flash light into the cylinder and watch for the pistion to reach the full stroke. At that point remove the cap on the mag and see if the roter is ready to point to number one spark plug wire. If its pointing to #3 your off 180 degrees. If the mag is attached OK connect it to a spark plug and see if you have spark. It may just need a new set of points and condenser.
Yugrotcart
04-16-2006 17:03:01
So does the mag work, or has it been bypassed.
jdo
04-16-2006 17:15:18
 Re: farmall H still wont start in reply to Yugrotcart, 04-16-2006 17:03:01
mag has been checked and does work
Yugrotcart
04-16-2006 17:22:28
 Re: farmall H still wont start in reply to jdo, 04-16-2006 17:15:18
If it does work, go with "Charlie M's" advise then.
