560 injector pump ?
TWL
04-17-2006 13:28:21
I need to take the injector pump and have it rebuilt.What would be the best way to remove and keep in time.Thank you for your help.
the tractor vet
04-17-2006 15:17:31
 Re: 560 injector pump ? in reply to TWL, 04-17-2006 13:28:21
well first shut the fuel off at the fuel tank clean the area all around the Injection pump then there is a small plat on the side of the pump that is held in place with two small screws remove the screws and look in there and you will see a line on one pice now turn the engine in direction of rotation till you see a second line on the othere disk when the two lines are lined up then pull the cover off the ft. of the timming cover and remove the nut and washer and with a puller mounted to push the shaft out then remove all lines linkage and the two-three nuts holdin the pump to the outside of the timming cover then with the puller push the shaft and pump to the rear and what ever ya do do not turn the engine over after the pump is off . Now since you are asken i am guessen that you do not have a book so GET ONE this is not one of them jobs for a novice and instalation must be done under vary clean conditions and settting the pump back up MAY require some adjusting and sometime YOU HAVE TO INSTALL THE SHAFT SEALS and this is not something that if you have never do it before as stright foward as it looks as the next thing is you will be back on here asken why ya got fuel in the oil.
Colorado Curt
04-18-2006 07:36:17
 Re: 560 injector pump ? in reply to the tractor vet, 04-17-2006 15:17:31
Those seals are a bugger to get back in right. It took me two tries.
It is a two person job. One to support the pump and the the other to manage the seal. I used a small, flat flexible piece of plastic to push the first seal in place.
the tractor vet
04-18-2006 16:01:24
 Re: 560 injector pump ? in reply to Colorado Curt, 04-18-2006 07:36:17
Ahhhhh ya just weren't holden your mouth just wright and i have never had and extra set of hands , oh wait a min i have the tool for that one can never have enough tools.
TWL
04-17-2006 19:21:37
Thanks Doc,I have removed the pump on our 401 JD backhoe and it has a similar pump.I done it just as you say here but the shaft stayed on and I put the seals on the shaft then installed the pump.Could this one be done the same way.I do appreciate your help.
captaink
04-18-2006 05:42:36
 Re: 560 injector pump ? in reply to TWL, 04-17-2006 19:21:37
It has been a while since I’ve had one off, but from memory I think you can. The issue then becomes the seals on the pump shaft and the fact that they are VERY, VERY vulnerable to damage when reinstalling the pump. I think the vet explained the "best" way to do it, not necessarily the fastest or easiest way.
I’m in the vet’s corner here, get a manual. The price you pay now sill save you much trouble and frustration in the future. The folks on this board can talk you through just about anything on fixing a tractor, but can’t replace the info in a good shop manual.
