Yesterday and today I began my first maintainence on my Farmall A. A quick history: I bought it about 2 years ago from the second or third owner who kept maticulous records of when fluids and all other maintainence was performed. It is a 1944 Farmall A.So the transmission change went well as soon as I identified the check and fill positions. The nut for checking transmission oil on the side of the tractor was under the left rear brake connecting rod. Was I supposed to disconnect the rod to remove the bolt? Today I removed and emptied the rear differentials. Now I have to get a long funnel to refill them. Is there an easier way (cleaner way) to remove the pans without spilling a bunch of oil on my driveway? I used a plastic pan that was just about an inch too short on both sides to allow a clean drop of the pan. I guess a bigger pan would be the answer? I don't use the PTO as of yet but I guess I should change that fluid while I'm at it. Is there a trick to doing that? Thanks for your input and tips. Even though I felt way out of my element I think I did a pretty good job of this round of maintainence. I use the tractor about 30 hours a year so far doing a lot of hauling of logs, firewood, horse manure for the garden and riding around the yard for fun and some bottom plowing in my 24X38 garden!
