966 injector
chadd
04-18-2006 07:44:26
Lately our 966 has had a fuel leak on top of the head. It seems to leak between the head and the top of the injector on cylinder number 1. I was just wondering how hard it is to put in a new injector, and if I need any special tools to do it. It is really starting to make a black gooey mess all over the top of the motor. Looks like tar. Thanks for your help.
the tractor vet
04-18-2006 08:31:31
 Re: 966 injector in reply to chadd, 04-18-2006 07:44:26
The seal on the bottm of the injector is leaking and you are getting compression up past , now it may come out easy and then again it may be stuck and may bring the injector tube with it now over the years i have been LUCKY and been able to get them out with out having the tube come with it , If the tube comes out then it will dump coolant into the cylinder so you may want to drain the system . As far as special tools go i have several injector pullers that i can use but my favorts are the two small injector pullers that look like small LADYS FOOT BARS . And if it will come out with out pulling the tube i use and injector tube cleaning brush to clean out the tube and install a new seal and clean up the injector and torque it back in evenly . If the tube comes out then ya have to install a new tube and have either and old junk injector to drive it in or the special driver to install the tube with .
