sickle bar for M model
Rusty Wrecks
04-19-2006 11:54:05
I recently purchased a Farmall M and would like to know if sickle bars are readily available for it. If they are where would I start to look for one?
Bill WIneman
04-19-2006 14:36:15
 Re: sickle bar for M model in reply to Rusty Wrecks, 04-19-2006 11:54:05
Lots of old mowers will work. If you are not afraid of green, we have used old JD #5's and newer models on our Farmalls for years. The trick is to get or make the hitch plate that bolts to the drawbar. Any old hydraulic cylinder, single or 2 way will raise a mower. The pto shafts are all more or less the same, maybe a length problem but nothing that can't be fixed.
The same type of hitch will work on C's if you bolt a regular dwarbar to the tractor. There was a pulley and cable arrangement to lift the JD mowers with a C that used the touch control unit.
old
04-19-2006 12:25:01
There where a few types that could be used with your tractor. One would be a trailor/pull type, which I have one of for sale. And there was a mounted type that could also be used
