hyd. belly pump off a M
Brad in WI
04-20-2006 01:49:13
Are the parts and pieces between two or more belly hyd. pump interchangable. I have one that appears to have been used and abused alot. I am thinking of purchasing another and making one good pump out of the two if need be. Will I encounter any large problems by making one from the two or should it work out.
Brad
Wayne Swenson
04-20-2006 10:33:24
 Re: hyd. belly pump off a M in reply to Brad in WI, 04-20-2006 01:49:13
Should not be any problems. Keep the pump gears as a set.
