Farmall M - brake band replacement
Jim Kuntz
04-20-2006 05:11:46
Am replacing rt. brake band on 1950 Farmall M . I am down to the assembly that contains the two pins that go thru ends of the band . Question is : how to remove those pins ?? Any help appreciated !!
Dave Slater
04-20-2006 06:17:08
 Re: Farmall M - brake band replacement in reply to Jim Kuntz, 04-20-2006 05:11:46
Tight fit or rust is all thats holding them.Take the brake lever off and key out of brake shaft that goes through cover,clean end of shaft with wire brush and lube a little before removing to inside of cover.Now you can drive pins out.
