farmall blocks
ronnie frazier
04-20-2006 09:27:59
I have a international T340 dozer with a C-135 gas motor.I have been looking at a farmall C tractor and others like BN,A etc. I belive these blocks are all the same outside dementions the bore is different but can a lot of these parts interchange?Also will a TD 340 motor interchange with a T340? Thanks Also can the sleeves be changed to larger bores like from a 123 to a C135or C146?
achodges1
04-22-2006 19:12:54
 Re: farmall blocks in reply to ronnie frazier, 04-20-2006 09:27:59
I bought a Super C service manual and the motor section is written mainly about the C-135. I think the blocks are the same as the C-123( Late model Super A,Super C, 200) but a little different from the C-113( Older Super A,B,C).When you put 3 1/4 bore sleeves in a C-123 its new displacment is 135. Don't know anything about dozers but think alot of C-123 and C-135 parts will interchange.
