wont turn over
itsrfarm
04-21-2006 14:33:34
I have a M with a new battery,new cables and new start switch,when I try to start it the only thing that happens is the switch starts to smoke.Any ideas?
Kevin Bismark
04-21-2006 17:32:31
 Re: wont turn over in reply to itsrfarm, 04-21-2006 14:33:34
Well, is the starter locked up, or the engine locked up, do you have bad connections at the starter switch, have seen the starter switches go bad and get really warm but the starter at least tried to do something, can you turn the engine over? and have you tried to take the starter off and try it with jumper cables?
Kevin
Nebraska Cowman
04-21-2006 14:59:08
Unless you are holding the button excessivly long smoke says loose connection to me.
CNKS
04-21-2006 14:40:30
Does the engine turn over with the crank? Or does the fan turn when you try to push it while in gear?. If not, the ring gear and starter drive are jammed. Loosen the starter to free it.
