656 Hydro, D282 timing marks
R Irons
04-21-2006 15:51:37
Our 656 Hydro with the D282 lost some teeth on the injection pump gear. I was able to locate a used gear and my local dealer rounded up the front cover gaskets etc...how do i line everything up? #1 up on compression etc... does anyone have a engine service manual they could scan and e-mail me the pages to do with engine/injection timing?
P Backus
04-22-2006 07:56:10
 Re: 656 Hydro, D282 timing marks in reply to R Irons, 04-21-2006 15:51:37
There are timing marks on the crank gear, and two marks on the idler gear and then one on the inj pump gear. I have the I&T manual for it and can probably scan that info to you if someone else hasn"t already. Just let me know.....
Paul
R. Irons
04-24-2006 16:41:53
 Re: 656 Hydro, D282 timing marks in reply to P Backus, 04-22-2006 07:56:10
Thanks for the reply, I think I was able to get the timing marks with that. She was a bit of a bear to get the fuel injector pump primed, though she seems to be running better now. Still a bit choppy, I hope it is just a bit of air in the fuel line yet and not 180 out, I can't see how it would be with all of the marks lined up and compression at tdc.
Thanks again.
