Order Farmall Cub Parts Online
Starting and charging a Cub
Chris(WA)
04-22-2006 06:48:54
I have what to many of you will be a dumb question I expect. How do you engage the starter on a white hood/ yellow belly Cub? Cannot see a pushbutton anywhere and the keyswitch does not seem to have a start posistion. {The key does turn harder than I expected though. Bad key switch?) How does the battery charge? It does not have an alt or gen on the waterpump belt and the starter has only the battery cable lug. No field terminal. Tractor does have lights and appears to be completely intact. Not mine YET. Wanted to get it runnng so I could decide on a price offer. Thanks for any advice. Chris
Merlin
04-22-2006 12:27:05
 Re: Starting and charging a Cub in reply to Chris(WA), 04-22-2006 06:48:54
If it"s a standard Cub, the late model ones had a safety switch that you have to have the clutch depressed to engage to starter. It also had an alternator and it sounds like someone removed it.
Peabody
04-22-2006 08:01:12
Yes, bad key switch. And those things had a combo starter/alternator on them
Chris in Washington
04-22-2006 12:07:39
 Re: Starting and charging a Cub in reply to Peabody, 04-22-2006 08:01:12
Hey there Chris. This is the first time I have seen you on here. Where are you located?
