686 Starter problem
Rollie NE,PA
04-22-2006 09:50:12
My neighbor has a 686 with the German Diesel engine. He has had starter problems ever since the original starter broke/cracked.He replaces a starter quit often. He says he can't seem to get a starter that works right even from IH dealers.
He just spent 700.00 to replace the ring gear on the fly wheel and after 30 to 40 starts the starter drive will not engage the ring gear.
My neighbor is 84 years old and still farming. I try to help him when I can. Any body have any suggestions?
Thanks.
Rollie
Janicholson
04-22-2006 19:13:28
 Re: 686 Starter problem in reply to Rollie NE,PA, 04-22-2006 09:50:12
I would look, and measure carefully the flatness and squareness of the mounting surface for the starter.
There can be several problems, like ovaled out bolt holes (from the cracked starter, or bad fron the factory surfacing of the mount surface. There may be a new (and supposedly much better) pinion available from Case IH dealers. I'm not sure which models, but it might be worth the research. Good luck, and thanks for helping others.
JimN
