Hey Harold Hubbard
Chris in Washin
04-22-2006 12:15:34
I found a used belt pulley oil tube for my Super C. It doesn't have a nut, though. Is the original nut something special or can I use an ordinary nut? Also, I see two holes that go into the transmission, one on the left side and one on the right. Which one does the tube go through?
Harold Hubbard
04-23-2006 20:31:21
 Re: Hey Harold Hubbard in reply to Chris in Washington, 04-22-2006 12:15:34
The tube goes in whichever hole is threaded, I think it should be on the right hand side as you face forward. The "nut" is a special, it is actually threaded on the outside, the hole through the middle is smooth. One side of the nut is notched for a spanner wrench, but the few times I ever removed it I used a hammer and punch.
