560 deluxe seat suspension
Joe Serrani
04-22-2006 15:34:46
Hi fellow tractornuts.. Has anyone had the opportunity to rebuild a 560 or 460 seat suspension.. there are 2 pins that if the holes they go through are worn it accelerates the side to side sway (see-saw)..Is there an easy fix that someone has come up with?? thanks
Joe
El Toro
04-23-2006 09:27:07
 Re: 560 deluxe seat suspension in reply to Joe Serrani, 04-22-2006 15:34:46
You may be able to get your machine shop to make bushings to remove the slop. Hal
