Re: SAMPLE engine marking on B
CNKS
04-23-2006 14:20:22
I have seen the "Sample" referred to before, but don't remember for what (but see my guess below). Your friends B was built at the Louisville plant shortly after it opened. The last A/B chassis serial is 198298 for Chicago and 220829 for Louisville. Very close to the introduction of the C and Super A thus the opening for the hydraulic pump. The engine prefix for the C was FCM, for the Super A FAAM. The A and B did not use the M. But, it looks like IH started using the M prefix a little early, which also may help explain the word "sample", although it is probably "supposed to read" FABM on the same line. Could be intentional, could be misstamped, since the serials were stamped by hand. The only G I can find is for a cotton picker attachment, never used on a B, I don't believe. Or, as you say, it could be a replacement engine.
JohnG(TX)
04-24-2006 10:58:39
 Re: SAMPLE engine marking on B in reply to CNKS, 04-23-2006 14:20:22
Actually, there was a cotton picker for a B. I have seen photos of it. Not real popular, and very low production. Probably really rare these days.
Dennis Stoeser
04-23-2006 19:34:18
This is cast in the block not stamped on the number pad. It is located down on the side of the block about 4 inches above the pan rail. I don't remember for sure but I think the cast date is 8 ?? Q which is August of 1947.
CNKS
04-23-2006 19:53:10
 Re: SAMPLE engine marking on B in reply to Dennis Stoeser, 04-23-2006 19:34:18
I didn't mean to imply that Sample was stamped, just the serial. I assume the serial is stamped on the pad -- if not I'm lost. Unless Gene or someone comes up with a better answer, I believe you have one of the earliest engines modified to accept the pump.
