C Farmall lights
thumbanger
04-23-2006 14:22:43
Working on lights all of the tractor is grounded other than light bar arms. Cant figure this one out it as if they were off tractor. Any help thanks in advance.
thumbanger
04-23-2006 18:56:42
 Re: C Farmall lights in reply to thumbanger, 04-23-2006 14:22:43
The light bar arms are not grounded I can put a ground to light and it will work. I have checked with test light all of tractor is grounded except for light bar arms.
55 50
04-23-2006 19:48:07
 Re: C Farmall lights in reply to thumbanger, 04-23-2006 18:56:42
So then do what Paul Shuler said and they will work!
Paul Shuler
04-23-2006 16:12:13
If your asking what I think your asking. The lights won't work when mounted on the tractor. Been there. I had to take the lights off and take a grinder and knock all the paint off the light bar where the bracket goes and inside the bracket to get a good ground befor they would work. It's been a while but I think the lights ground inside the teardrop light case so the braket and light bar need to be clean and bare to make a ground.
CNKS
04-23-2006 14:40:07
I don't understand your question. If the bulbs and switch are good, and everything is wired correctly, you likely have a bare wire touching metal inside the steering post or light bar. Pull out the wires and replace, if you can't locate it.
