Super M Missing
IllinoisFarmall
04-23-2006 17:56:14
My 53 Super M has developed a pretty bad miss and loss of power when under a heavy load. I pulled the plugs and they were very wet/oily. The exhaust is also smoking quite a bit. I assume the fuel mixure is too rich. I closed the main fuel set screw about 3/4 turn and it didn"t seem to help. How can this problem be fixed?
55 50
04-23-2006 19:45:25
 Re: Super M Missing in reply to IllinoisFarmall, 04-23-2006 17:56:14
Plugs don't get oily because of a bad carburetor. Maybe the engine needs an overhaul, new rings and such.
RustyFarmall
04-23-2006 19:27:57
The first thing you need to do is get 4 new spark plugs. There's probably nothing wrong with you carburetor.
old
04-23-2006 18:52:35
You might try turning the main jet in till it starts to die then back it back out about a half turn. Then give it a try, you may have to play with it a little to get it just right
