Super A, C Hydraulic Block ??
terryjd98
04-23-2006 19:35:11
I was wondering if anybody could give me the website of the company that sells the small hydraulic blocks that go on the SA, SC? The blocks I mean are the ones that go between the steel lines and the pump so you can add aftermarket controls. Thanks Terry
gene bender
04-24-2006 00:38:39
 Re: Super A, C Hydraulic Block ?? in reply to terryjd98, 04-23-2006 19:35:11
Why dont you just make one or use the threaded ports that are already there. Some just add one in series in the pressure line by brazing a couple fittings. Or you can get the original line from a salvage yard.
Nat 2
04-24-2006 04:41:00
 Re: Super A, C Hydraulic Block ?? in reply to gene bender, 04-24-2006 00:38:39
If you can just use the threaded ports, then why does CaseIH sell the bypass block?
I think if you use the threaded ports, you disable the touch control.
CNKS
04-24-2006 05:13:25
 Re: Super A, C Hydraulic Block ?? in reply to Nat 2, 04-24-2006 04:41:00
I didn't know Case-IH sold the bypass block. The "manifold" and lines for the remote or fast hitch attachment are interchangeable with the ones for the touch control levers alone, but they are different, also hard to find. Thus the aftermarket blocks.
CNKS
04-23-2006 19:44:12
More than one source, but www.saginawcountytractor.com has them, don't think their website lists them, you will have to call.
