Order Farmall Cub Parts Online
help for a smoking cub
Buffc
04-24-2006 04:55:38
I recently bought a 1961 cub...smokes some mostly under a load, but smokes. The tractor was not used much or at al lfor over a year before I got it.
I have been told of a gas/oil additive called Sea Foam to help seat or clean the rings to help with the smoke...
Any suggestion?
Thanks
Nat 2
04-24-2006 10:44:58
 Re: help for a smoking cub in reply to Buffc, 04-24-2006 04:55:38
You can get SeaFoam at Advance Auto Parts, and probably most any other big-chain auto parts stores.
capaink
04-24-2006 09:13:50
I tried Sea Foam Deep Creep and Rizlone oil additive in my backhoe that was profusely using oil and smoking. I have to admit that it helped, but I finally ended up tearing it down and doing a rebuild. After I got it apart and saw how bad the cylinders, rings, and bearings were worn, it was no wonder why it was still using a quart every two hours!
Good luck!
Bigdog
04-24-2006 05:58:54
Sea foam does work well if the rings just need to re-seat. If they are worn, nothing short of a rebuild will correct the problem. Is this blue smoke?
buffc
04-24-2006 13:31:45
 Re: help for a smoking cub in reply to Bigdog, 04-24-2006 05:58:54
During usual running, slight blue smoke, not heavy. If I sit at idle for a few minute, it is heavier when starting workm again
Thanks, Buffc
