Farmall B Ser. #125?? PROTOTYPE??
Rob Bush
04-24-2006 06:24:02
Hi! Really need some help on this one! Went to an auction over the weekend in SE Wisconsin and almost over looked a pretty tough looking Farmall B basically good for parts. It has the exaust lift on it and looks like any normal B except for the serial number plate and location. It is on the seat post like the rest of them, but turned 90%-I can tell it's original. All B's that I've seen have a serial number tag that says" FAB XXXX" as a serial number and an RPM rating of 1540. This one Says "FRB 125" and has an RPM rating of 1500. Why does this one say FRB instead of FAB? the number is 125 as clear as day-what does the "R" mean in FRB? All IH's started with a number of 501. Mine is 125? The RPM is different and the tag is turned 90 degrees from the factory? What tractor is it that I have? Can anyone tell me about this little B??
Thanks So Much For Any Input!! Rob Bush
brainerd dave
04-24-2006 08:43:46
 Re: Farmall B Ser. #125?? PROTOTYPE?? in reply to Rob Bush, 04-24-2006 06:24:02
Rob,
I can't find any reference in Guy's book that would support either that serial number or the FRB prefix. Perhaps you have a replacement tag that was stamped incorrectly. What is the serial number on the block? Some even had the FAB prefix on the block serial number, some did not.
Guy Fay
04-24-2006 17:27:24
 Re: Farmall B Ser. #125?? PROTOTYPE?? in reply to brainerd dave, 04-24-2006 08:43:46
You're looking in the wrong book. Should be looking in the Experimental and Prototype book. Allready talked to him.
Frameall. Damn, I was thinking about going to that auction, too.
brainerd dave
04-25-2006 12:37:55
 Re: Farmall B Ser. #125?? PROTOTYPE?? in reply to Guy Fay, 04-24-2006 17:27:24
I enjoy the book I've got and thank you for putting it out, but I'm not buying another one:)
What does the man have?
Rob Bush
04-24-2006 10:11:03
The ID tag is 100% visable, but aged just like the tractor. I'm 110% sure it's the original tag. The block has NO serial number on it like most others do.
Thanks for looking!
brainerd dave
04-24-2006 10:26:34
 Re: Farmall B Ser. #125?? PROTOTYPE?? in reply to Rob Bush, 04-24-2006 10:11:03
Are you able to find any casting codes?
That should get you in the ballpark.
brainerd dave
04-24-2006 10:22:47
