steering arm needed
Marvin Gill
04-24-2006 16:07:01
Hi everyone, I was wondering if anyone has a good used center steering arm for a wide front 1953 Super M? Thanks--Marvin
mgnlenore@yahoo.com
Janicholson
04-25-2006 12:24:29
 Re: steering arm needed in reply to Marvin Gill, 04-24-2006 16:07:01
If you put a 2X4 between the drag link, and the axle and clamp it in place with three C clamps, you could move the tractor to get near the power. Just loosen and turn tighten and move (it might take 30 minutes), no road driving however!!!
JimN
Nat 2
04-25-2006 06:50:16
Still in the mudhole?
Take that to a professional welder. They should be able to weld it back together for you, and beef it up a little. A "new" replacement part will just break again in the same place.
BTW, that's the "old style" wide front.
Marvin Gill
04-25-2006 10:26:28
 Re: steering arm needed in reply to Nat 2, 04-25-2006 06:50:16
Thank you all for your input. Nat, that sounds like the right thing to do. Thanks for telling me the term for my front end. I didn"t quite know what Jim meant. I am having a heck of a time getting this thing unbolted. I would use an impact wrench but the tractor is not near any power source and I don"t have a generator. Does anyone know if it is best to raise the front end up when I bolt everything back together or is it okay to leave it as it sits? Thanks again--Marvin
Jim J
04-24-2006 16:53:45
What kind of wide front do you have?
Marvin Gill
04-24-2006 17:07:04
 Re: steering arm needed in reply to Jim J, 04-24-2006 16:53:45
third party image
Jim J, I have an adjustable wide front end. I need the piece in pics 1a and 1b. Thanks--Marvin
El Toro
04-24-2006 16:38:01
Here's a web site for tractor salvage yards. Some may be in your area. Hal
http://www.epartdirect.com/index.php?t=fc&s=s
