Lift-all removal hints?
unioncreek
04-25-2006 06:34:59
I need to remove my lift-all on my M to replace the seal in it. I know that the coupler needs to be lined up correctly to drop the pump. How do you get the coupler on the tranny side off? Does it screw off or what? Just would like to have everything cover so I don't get any surprises.
Thanks,
Bobg
Wayne Swenson
04-25-2006 09:01:30
 Re: Lift-all removal hints? in reply to unioncreek, 04-25-2006 06:34:59
On the M, the coupler is a disc with cross pieces formed at right angles on opposite sides.
It will fall out when removing the Lift-All; tape the coupler to the transmission coupler drive when reassembling and have it aimed straight up & down. Align the driven part on the Lift-All and slide them together on the way up.
The drive coupler on the transmission is threaded on; turn left to remove. Put the transmission in reverse and lock the brakes to allow you to loosen the coupler drive.
Nat 2
04-25-2006 06:51:52
You can completely remove the coupler with the Liftall in the tractor. It just slides out after you remove two roll pins, one on each end.
RustyFarmall
04-25-2006 11:57:49
 Re: Lift-all removal hints? in reply to Nat 2, 04-25-2006 06:51:52
Nat, that is true for an H, an M is different, the coupler has to be removed at the same time the pump is dropped.
