M leaks gas
M leaks gas
04-25-2006 14:18:40
When I shut off my M she leaks gas where the choke lever attaches to the carb. Eventhough I close the gas line to the carb, gas already in the line leaks like crazy. But when I pull the choke rod out the leak stops. What's happening? What's the best fix? Thanks.
RustyFarmall
04-25-2006 17:33:37
 Re: M leaks gas in reply to M leaks gas, 04-25-2006 14:18:40
It's time to replace the needle valve and cage, or at least remove it and do a cleaning. Gas should not leak from the choke lever area no matter what position the lever is in.
CNKS
04-25-2006 14:48:00
Haven't had one apart for a while. If I remember right the choke shaft needs new packing, when you pull the rod it moves it so that it stops leaking.
arod
04-25-2006 14:28:18
needle valve is not seating correctly
