460 IH hydro oil fill ?
maplehillfrm,pat
04-25-2006 19:56:52
hello all, a friend of mine just got a 460, not a utility, it is a 6 cylinder high model, is the trans/rear end a common resevoir for the oil like my 454 and others,? and where is the hydro fill on this , I see a plate on top of transmission just under the steering dash, possible fill point"? I dont see any other nut or plug, , I know my 454 fills directly behind the fuel tank in a plug, any help would be appreciated, pat
Allan In NE
04-26-2006 04:17:03
 Re: 460 IH hydro oil fill ? in reply to maplehillfrm,pat, 04-25-2006 19:56:52
Maple,
I really doubt if your friend's 460 even has a hydro. They didn't come out until the 56 series if memory serves.
Allan
maplehillfrm,pat
04-26-2006 21:29:16
 Re: 460 IH hydro oil fill ? in reply to Allan In NE, 04-26-2006 04:17:03
yes sorry I meant hydraulic, it has gear shifter, my fault, sorry, will you forgive me, thanks pat
Nat 2
04-26-2006 05:26:40
He's using "hydro" as an abbreviation for hydraulic, or "hydrolic" for those people who can't spell or be bothered to use a spell checker :)
Allan In NE
04-26-2006 05:30:31
 Re: 460 IH hydro oil fill ? in reply to Nat 2, 04-26-2006 05:26:40
}Smile{
Broomstacker
04-25-2006 20:11:35
Yep, that plate at the base of the dash is the fill point. Transmission, rear end and hydraulics take 10 gallons of Hy-Tran. The over-flow full indicator is down on the left side, the access plate for the filters is down on the right side.
There is a separate system for the PTO.
maplehillfrm,pat
04-25-2006 21:24:17
 Re: 460 IH hydro oil fill ? in reply to Broomstacker, 04-25-2006 20:11:35
thanks I appreciate it, I will let him know tomorow , pat
