OLD TRACTOR!! NEED INFO!!
Lance McLamb
04-26-2006 13:54:32
I am the owner of a very old international farmall tractor. and if anyone can tell me a good site to be able to track its history back i would be very gratious. If so please contact me at Rodsbabyboy@aol.com Thanks
PAULIH300
04-27-2006 02:52:24
 Re: OLD TRACTOR!! NEED INFO!! in reply to Lance McLamb, 04-26-2006 13:54:32
The tractor should not say International Farmall.Farmall was the rowcrop side of the business and was usually associated with McCormick,the International side was industrial and those tractors will be labeled as Internationals(for example you will never see a Farmall 300 Utility),Cub models had both labels and some export tractors crossed the line (some Farmalls were called McCormicks exclusively).
old
04-26-2006 14:52:11
Sorry but theres a lot of differant very old Farmall tractors and with out a lot more info I'm sure we can't help. You need to tells use as much as you know about it and a picture would go a long ways also. Shoot from what you have said it could be one of about 200 models if not more
Dave BN
04-26-2006 14:50:03
The folks on this site are as good a resource as you will find. It would help if you could post a picture or at least give a discripton. Many tractors have been modified to some extent over the years so yur discription may not match an exact modle. I too would look thrugh the Galleries section on the left. the serial numbers section of the Research & Info, also on the left side if this page, would help if you can find the serial number of your traactor. Hope you get the help you need. Dave.
Illinois Boy
04-26-2006 14:05:22
If that's all you know about it - "Old International Farmall Tractor", there are several good books out there that could help - also might try your public library and try to match up some pictures. If you can get a model number or letter, that would help.
captaink
04-26-2006 14:07:19
 Re: OLD TRACTOR!! NEED INFO!! in reply to Illinois Boy, 04-26-2006 14:05:22
Also the tractor photos link on the left may help.
