INT'L 300U: stuck engine
apekim
04-27-2006 10:09:51
I was recently given a 300 utility tractor. It appears the engine is stuck. Anyone have any recommendations as to what to dump in the cylinders to free it up? It's not that easy to get a tool between the front axle tube and the lower engine pulley to turn it over by hand.
Mike
gtx1967jewison
03-07-2009 12:29:40
 Re: piston clean up in reply to Janicholson, 03-06-2009 10:46:38
WRONG! read the guy above- no steel wool. but also NO sandpaper. its 2009! ever hear of 3M scotchbrite? even comes in 4 different "grits"! i would recommend the red color.
Bill46
04-28-2006 10:32:22
 Re: INT'L 300U: stuck engine in reply to apekim, 04-27-2006 10:09:51
Well...if you want to take Randy's advice...heck I might offer you a few $ and come get it out of your way. I have a fresh 350U engine I can bolt right up.
Quebec Red
04-27-2006 18:11:38
Could be your starter that is hanging up. Carefully remove it and try to turn the motor by hand. Maybe. QR.
Janicholson
04-27-2006 11:45:20
There is a crank "shaft" sticking out of the front for a hand crank. Putting a crank on it. applying pressure, and hitting the starter can be of advantage.
JimN
old
04-27-2006 10:19:20
This is what I do and so far it has worked about 99% of the time. Only had one engine it didn't work 100% on. I fill the cylinders with tranny fluid, then walk away for a few days, put the plugs back in to keep dirt etc out of the engine. Then put a battery in it and every day go out and hit the starter a few times, watch the crankshaft pulley, if it moves any at all. The remove the plugs and keep hitting the starter just nice fast hits don't hold the starter button. If it moved any it will brake free. Now if it hasn't broke free in say 2 weeks then top the cylinders off with turpentine, not paint thinner but the good old true turpentine and wait another week. Then give the starter a try again. Check out the web site a few of the tractors pictured there where locked up when I got them and now run well
randy
04-27-2006 10:17:43
was someone mad at you or just plain didnt like you to give you a 300u ??? leave the engine stuck and plant flowers around it!!!!
Ron Sorden
04-27-2006 16:19:31
 Re: INT'L 300U: stuck engine in reply to randy, 04-27-2006 10:17:43
Hey Randy I resemble that remark!!
Ron
