Order Farmall Cub Parts Online
fitting a woods 42a to a farmall cub?
buffc
04-27-2006 15:49:19
I purchased a woods 42" belly mower for my cub but the mower turns out to be a 42a with bracket that has in line pulleys centered on the bar.
The bracket would fit if I remove my drawbar...
I was told that with a 90 degree pulley adapter it might work...
I"m not sure.
Any feedback would help.
Thanks
Farmall Ed
04-28-2006 05:22:10
 Re: fitting a woods 42a to a farmall cub? in reply to buffc, 04-27-2006 15:49:19
Buff, I dont understand exactly what you are saying, I just installed a 42 inch belly mower on my cub for the first time the other day, My bracket sits on top of the drawbar and clamps on with to steel straps. If your pulleys are in the center that would make them out of line with your power take off pulley. I am sure there are some people on here that can give you better advice than I can. Does you tractor have hydraulics? If it does let us know, I may be able to help you with that. Have a good day.Ed
gene bender
04-27-2006 18:23:59
WOODS is the place to ask. Unless you want to take to a fab shop and let them make it run.
