Need mirrors for 1066
JM in Merit
04-27-2006 16:44:10
Need to get some mirrors for my 1066 (cab) I can not see behind my baler when roading it. Hate to make a left turn and someone is passing me. Any type I should/should not get and where be a good place to get them.
Thanks
Nat 2
04-28-2006 05:09:09
 Re: Need mirrors for 1066 in reply to JM in Merit, 04-27-2006 16:44:10
Go down to your local big-chain auto parts store and pick up some replacement mirrors for a pickup truck.
Or, just turn your butt around and look out the back window, fer cryin' out loud :)
JM in Merit
04-28-2006 06:49:19
 Re: Need mirrors for 1066 in reply to Nat 2, 04-28-2006 05:09:09
If I could see through the belts on the baler I would. My older baler had enough room between the belts so I could see a car/truck. This newer baler has belts that are closer together so all I see is black belts
IaGary
04-28-2006 03:31:32
JM I got mine for a 1086 from Sloan.
They would fit the 1066 also without to much work.Might even fit better.
www.sloanex.com is there web site.
Good Luck, Gary
K.B.-826
04-27-2006 22:29:13
The newer Deere tractors, such as 7800's, 8100's, ect., use mirrors that just clamp to brackets that are nothing more than 3/4"(?) round tubing. You could go to your local Deere dealer and pick up two mirrors for a 7800 and make your own brackets from round tubing. Or you could buy the mirror brackets (expensive) from Deere and mount them to your cab.
