444 Electric Fuel Pump woes
Engine One Eigh
04-28-2006 08:12:54
My IH 444 gas tractor has a near new electric fuel pump from NAPA. The tractor will run for 3 or 4 minutes then die from no fuel. If you turn the key off and back on you hear the pump start again. So, the pump is stopping and thus running the tractor out of fuel. If you do not start the tractor but just leave the key on the fuel pump never quits. So why does it stop while engine is running and never stop when engine is not running? Any ideas?
TM nj
04-28-2006 09:41:50
 Re: 444 Electric Fuel Pump woes in reply to Engine One Eight, 04-28-2006 08:12:54
You may want to check all the electrical contacts.Sometimes wires lose continuity and switch prongs become loose causing intermitent problems.
Tom
the tractor vet
04-28-2006 08:24:54
And there is a electric fuel pump WHY ????? News to me i must have missed 444 101 must have slept thru the class .
CNKS
04-28-2006 17:47:45
 Re: 444 Electric Fuel Pump woes in reply to the tractor vet, 04-28-2006 08:24:54
Why what? 444's have electric pumps.
