2 tractor family
ken vt
04-28-2006 14:10:51
I finally went and did it. The 240U looked lonesome so I just bought a 350DU to keep it company. I am starting to get used to a diesel and it is sure different. So much power. Some questions... What is the butterfly valve in the intake manifold? Somebody tied it open and it looks like it could be a cold start choke of some sort. Where do I find where to check the tranny level?
I feel really fortunate for everything works including the TA, just a bit rusty and needs some brake disks and a muffler. Has a Lord loader, does anyone know anything good or bad about the loader??
thanks, having great fun cleaning up this spring with the new tractor.
ken
TDK
04-28-2006 20:44:59
 Re: 2 tractor family in reply to ken vt, 04-28-2006 14:10:51
It's called an air restrictor valve. Engine shuts down by stopping fuel supply. The only reason for the restrictor that I can see is to hold heat in the manifold when heating prior to starting. Maybe someone else has a better answer.
HAS
04-28-2006 15:12:32
I think the butterfly valve is how you would shut down a runaway diesel. Some diesel were shut down normally by shutting off the air supply.
