Order Farmall Cub Parts Online
Cub--How can I use an A carb (Zenith) on a Cub?
gpogpo
04-29-2006 11:01:49
Can't find an affordable IH carb for a Cub but I have a few small Zeniths off of A's and B's. I adapted a Zenith to fit but it seriously over-fuels the tractor....black smoke and no power. I could put in a smaller venturi (15/32") but I think the main jet would be too big. Would it be possible to epoxy the jet and drill it out to a smaller diameter (size?)....or maybe braze or silver solder the hole and drill that out smaller? Anyone ever done anything like this?
gpogpo
04-29-2006 19:17:14
 Re: Cub--How can I use an A carb (Zenith) on a Cub in reply to gpogpo, 04-29-2006 11:01:49
Well, I don't have "the old carb." Just trying to be creative. Actually, I already started--after I posted the first question. I silver soldered the zenith main jet shut and rebored it to smaller Cub carb main jet size (.036" I think). I used a small Zenith 15/32" venturi. Don't know what application that had originally. Last step is to re-drill and tap the mounting holes to Cub manifold size. It will be intereswting to see how (if) it works. All it cost was 1/8" of silver solder!
john *.?-!.* cub owner
04-29-2006 18:49:11
check the link below for repairing your old carb
04-29-2006 18:51:05
 Re: Cub--How can I use an A carb (Zenith) on a Cub in reply to john *.?-!.* cub owner, 04-29-2006 18:49:11
won't let me post the link, but copy and paste Link
El Toro
04-29-2006 18:36:54
Why don't you rebuild the old Cub carburetor instead of cobbing up a jerry rig. OEM Tractor
has a new carburetor for sale at 1-800-283-2122.
Hal
