Re: 560 Gas
the tractor vet
04-30-2006 09:07:35
The operators manual is a good thing to have and the rest IMPO the rest is a waist of money since your not into the parts business and part no. changes as fast as one changes his socks nowdays i leave that to the dealers to keep up with . Now down to the nitty gritty since more after market parts for the %^)'s as far as engine kits go they have for the most part all gone to the pistons for the 706 with the 263 and over the years who knowes how many times that head has been plained down and caused the comp. ratio to be increased use to be a standard at the machine shops to stamp the head on how much has been removed but now today nobody does it and nobody even checks to see how thick it is they just mill it and here ya go now it is your problem . And believe me when i tell ya that running the 87 octain gas is not the way to go and a 15-40 is not the oil to run unless it meets the low ash req. , yea i know well it works for me till ya wipe out a exhaust valve and come wineing that i have a burnt exhaust valve why did this happen because ya did not ust the corret oil in the engine or i have scored sleeves and pistons why because ya have the wrong gas it it or ya have the timming set wrong or ya weened back the load screw back to far .
Lance R.
04-30-2006 11:29:12
 Re: 560 Gas in reply to the tractor vet, 04-30-2006 09:07:35
Our IH mechanic gave my brother holy hell for not using low ash oil in his 606 gas. He always used 15-40 diesel oil in it. It reminds me of the oil filter comercial that said "You can pay me now or pay me later." My brother paid dearly later! As far as gas is concerned the jobber always mixes an octane booster in all of our farm gas.
CNKS
04-30-2006 10:27:50
"And believe me when i tell ya that running the 87 octain gas is not the way to go and a 15-40 is not the oil to run unless it meets the low ash req. , yea i know well it works for me till ya wipe out a exhaust valve and come wineing that i have a burnt exhaust valve why did this happen because ya did not ust the corret oil in the engine or i have scored sleeves and pistons why because ya have the wrong gas it it or ya have the timming set wrong or ya weened back the load screw back to far ."
I find your posts difficult to read, for obvious reasons so I usually don't read the whole thing -- you don't know it all, no one does. Many things cause engine problems, from normal wear and tear to abuse. If you listen to the engine under load, it will tell you whether you need higher octane gas, ie detonation. High octane gas and low ash oil are not going to cure abuse, or normal wear and tear. About any current oil on the market now should be better than the ones sold when IH came out with the low ash thing 30-40?? years ago. "The operators manual is a good thing to have and the rest IMPO the rest is a waist of money since your not into the parts business and part no. changes as fast as one changes his socks nowdays i leave that to the dealers to keep up with " The dealers computers change it automatically, I just give them the number and in maybe 30 seconds he can tell me whether he has it or not. And yes I am in the parts business for my own tractors. In order to be certain I'm getting the right part, I look the number up first. It is much faster than having the parts man do it.
