Fast Hitch Hose Blew
Tweeter
04-30-2006 11:15:38
One of the two rear hydraulic hoses for the fast hitch on my 330u blew the other day. Do I have to remove the valve to disconnect and reconnect the old and new hose? If so I am going to replace both hoses at this time. What size o-rings do the valves take? What size hose do I get for this? I had a rock rake up on the back and next I knew it it was resting on the ground with hydraulic fluid over everything.
Tweeter
04-30-2006 13:18:23
 Re: Fast Hitch Hose Blew in reply to Tweeter, 04-30-2006 11:15:38
Yea, they both look the same age. I do plan on replacing both.
evilbowevil
12-31-2009 07:44:26
 Re: '48 Cub hydraulics question. in reply to BenB, 12-30-2009 22:03:45
ralphscubs.com will have all the parts needed to do this
good luck
Ron
BobG in VA
04-30-2006 11:59:12
Well as I remember (that may be a problem though...), when I blew a hydro hose on the 53 SC from the valve to the block (about 3 ft), I took the old one to TSC and found a good replacement already made up. I 'rigged' it and its fine. Been doin' OK for a couple of years now. Check out TSC, they may have a replacement that fits right in. BobG in VA
El Toro
04-30-2006 11:54:40
The same thing happened on a Super C. I made up new hoses in at work and replaced both hoses. Very easy to make your own hoses. Hal
Janicholson
04-30-2006 11:30:57
A crows foot wrench (for 3/8" drive tools) will get in there and loosen the hose. If they are the same age, doo both.
JimN
