460 clutch pedal
uncle fred
04-30-2006 11:44:53
I have a 460 with a worn clutch pedal shaft. It is a restoration project.
The shaft is wore beyond just a new bushing in and I would like to know how others have fixed this issue.
Has anyone welded the shaft up and ground down while it is in the tractor? Thanks.
binderpower856
04-30-2006 12:03:22
 Re: 460 clutch pedal in reply to uncle fred, 04-30-2006 11:44:53
Best way I found was to buy a new shaft from OEM Tractor parts. You can also send them your clutch pedal and they will machine it out and put a new bushing in it. I think last time I had it done I ended up with about $80 in it. Here's a link to their brake shaft parts. >Link
The>Link part number you need is 370874R1
Bill
CNKS
04-30-2006 13:47:14
 Re: 460 clutch pedal in reply to binderpower856, 04-30-2006 12:03:22
I didn't read all your post before I answered below. You're saying OEM did the machine work and shipping for $30? That's pretty good.
agpilot
03-07-2009 09:42:56
 Re: Friendly message to Dwight selling the Super C in reply to Hugh MacKay, 03-07-2009 08:37:33
Soon be my 67th birthday so I may as well do the engine, buy rear tires and rims, then take it with me when I go. Just think Kirsch, they could dig an 8' deep hole put me on bottom, with 130 down to axles as a grave marker. Should hold me down.----- ----- ----- ----- ----- Hello Hugh: In reply to your comment above, I posted a picture of a Farmall in a Funeral on one of my blogsites. Hope it helps? Why not get one more last ride? ag
Link 4 pix if link fails:http://oldfarmitems.blogspot.com/
uncle fred
04-30-2006 12:21:38
What's involved in the shaft's removal and installation? DOe sit simply slide out from one side?
CNKS
04-30-2006 13:42:39
 Re: 460 clutch pedal in reply to uncle fred, 04-30-2006 12:21:38
It just slides out. Any good machine shop can make a new shaft, build up the clutch pedal hole and install a bushing. Had one done last summer for about $105. OEM's shaft is $49.50. Typical machine shop charges are $50/hr, more or less. If you sent the pedal to them and had them build it up and bush it, two way shipping would cancel out any price advantage.
