Major engine problems?
JasonT
04-30-2006 18:16:17
Hello everyone,I have a tractor with the D-239 engine in it.Ive owned it for about 5 months.It has always smoked white smoke when it starts until water temp reaches about 140 deg.It runs great and starts right up.Today when I started it I noticed the faint smell of antifreeze from the exhaust.I checked the radiator and found it a little low from when I changed it this January.Does anyone have any ideas? the oil is clean possible head? Thanks Jason
kennebunksawmill
03-07-2009 15:29:28
 Re: charging question in reply to gene bender, 03-07-2009 15:09:10
thanks, how do I do that?
Allan In NE
05-01-2006 04:08:48
 Re: Major engine problems? in reply to JasonT, 04-30-2006 18:16:17
Jason,
Don't get in too big of a hurry to tear it down. Sounds plumb normal to me.
They always smoke on startup and they ALWAYS puke antifreeze if they are over full. If you look in the radiator of one that has been working real hard, you'll find that the level is down quite a ways from the neck.
I'd just watch it for a few weeks. If there is no antifreeze in the oil, I really doubt you have a problem.
Allan
MN Scott
04-30-2006 20:16:31
German's are famous for smoking when cold. Are you sure it isen't just unburnt fuel from a cold engine?
El Toro
04-30-2006 18:33:56
You should look for bubbles in the radiator. The head may be cracked. If you pull the head and don't see anything wrong with the head gasket I would have the head magnafluxed. Have it checked for flatness too. Hal
