? about super A top side pto
banjo
04-30-2006 18:36:00
I bought a couple junk tractor and wondered if the pto units are the same off a super C and B as the super A. My super a does not have the side ways pto on it and wondered if i could pull it off a b or super c .
The super c has the belt pully and the b just has the shaft.My super a has the lower shaft , but not the top side mount. Thanks.
CNKS
03-10-2009 18:02:20
 Re: IH 434 colors in reply to Bob in Mi., 03-10-2009 17:52:33
I can't specifically answer your question, I can only say "probably", as most IH tractors had "industrial" versions. But, in some cases it could have been just a different color paint. Others had more extensive differences.
P K Ouellet
03-07-2009 10:59:38
 140 hydraulic system in reply to Bob in Mi., 03-10-2009 17:52:33
gene bender
05-01-2006 02:18:26
 Re: ? about super A top side pto in reply to banjo, 04-30-2006 18:36:00
The "top side pto" is for belt pulley and fitting from one tractor mite not always work. The best and only way you will know from what parts you have would be to take apart and go from there.
CNKS
04-30-2006 19:50:28
Far as I know they are the same--if not I will be corrected.
