utility tractor
BLACKnBLUE
04-30-2006 18:48:06
I am looking at buying a internaional utility, I don't know the number of it as the emblem is missing it just says utility. It is a 4 cyl gas. I want to use it to run a brush hog for 35 acres, will this tractor be good for this? I currently have a Massey TEA-20 and it is to small for the brush hog. Is there anything other than normal that I should be looking at for wear on these utility tractors? There is a large handle that comes up the left side beside the steering wheel area, what is this lever for?
Thanks
kennebunksawmill
03-07-2009 10:06:04
 Re: charging question in reply to teddy52food, 03-07-2009 09:56:10
When I shut it down, it showed 6.1V....I didn't see any bubbling @ top of battery...but, only ran it about 1/2hr.
YTSupport
03-07-2009 07:14:08
 Re: piston clearance in reply to Janicholson, 03-05-2009 18:30:17
Please ignore, recovering the board by replying to top message.
Brownie 45
05-01-2006 05:23:17
 Re: utility tractor in reply to BLACKnBLUE, 04-30-2006 18:48:06
The lever should be the torque Amplifier . See if you can locate a tag[aluminum or brass] with numbers/ letters which would help identify this unit. Check for it on the bellhousing. Picture would help.
