706 w/282 no sleeves
Jayairing
04-30-2006 19:14:32
I have an early model 706 with a 282 diesel that I am rebuilding. When I pulled the engine down I discovered that it had no sleeves in it. It also has no grove cut in the top of the cylinder wall for the sleeve to seat in. There is no sign of filler or welding, and the block was not bored out. Appears to be factory. Just has over sized pistins in it. Has anyone ever seen this before?
Smith1000
03-07-2009 12:52:12
 Re: Super C High Idle? in reply to Smith1000, 03-06-2009 03:55:47
Adjusting the screw was ineffective. It seems as if it is not hitting anything, which probably means the spring is off or broken. I can run it all the way up, or take it out completely and it behaves the same. There is another adjustment bolt on top, but it does not seem to make contact with anything either. I guess the governor will need to come apart.
MN Scott
04-30-2006 20:10:06
 Re: 706 w/282 no sleeves in reply to Jayairing, 04-30-2006 19:14:32
Most likely a combine engine, they used no sleeves.
Jayairing
04-30-2006 20:10:05
Turns out that my 282 might be a 301 instead. Same block, no sleeves, bigger pistons. If I"m wrong let me know.
