electronic ignition
texas300U
05-09-2006 09:59:12
Has anyone replaced the points with electronic module on 1955-56 300 utility? Just wondering what kit to get?
Canetractor
05-10-2006 08:13:33
 Re: electronic ignition in reply to texas300U, 05-09-2006 09:59:12
Found a lower price source for electronic ignition kit k2543. qkits.com $16.95 +ship. My Farmall H running for 4 years with this kit modified for 6 volts. Ford 601 5 years on 12 volt version of same kit. Search web "kit k2543" for lots of info and skill level for assembly.
canetractor
05-09-2006 18:27:32
Another choice for those on fixed income is an electronic ignition kit. $20 plus shipping and 30 minutes to assemble, understand that everyone can't assemble it but most can. This system is similar to early cars that retained the points but reduced amperage thereby points last. The spark is unbelievable hot with original coil. Only internal modification is remove or disconnect condenser. Instructions are good. Ck. www.hobbytron.com search k2543
PAULIH300
05-09-2006 14:41:30
I have the 12V neg grd kit from Pertronix in my Ute,and it doesnt skip a beat with it....Vs the antique point setup.
Rcubed
05-09-2006 13:50:35
I paid $35 for my Case VAC and now I need to pay $92 to put electronic ignition on it! Bad news!
Marv
05-09-2006 13:07:58
Had problems with mine until I put a coil on that is compatible with the electronic ignition. Good luck. Marv
El Toro
05-09-2006 12:23:10
Here's a web site for their electronic ignition kits. Hal
http://www.farmersservice.com/distributors.htm
Wes in Ohio
05-09-2006 10:08:01
I put electronic ignition on mine got everything I needed from Genesee products www.geneseeproducts.com or 918-274-8000. good company answered all my questions
