H generator?
TomCline
05-09-2006 13:23:11
Hello all,
I have a generator supposedly taken off an H.
Stamped on the gen is - 1701355. This is a 2 wire, 3 brush unit.
When running the tractor, the generator puts out positive voltage. The tractor is wired positive ground. Is there a method to polarize this thing? OR - is this the correct generator in the first place?
Any help is appreciated.
Thank you.
TomC
Tom Cline
05-09-2006 13:54:13
 Re: H generator? in reply to TomCline, 05-09-2006 13:23:11
Bob M,
Thank you. That is what I needed.
The gen. fits fine. I had forgotten how to polarize. It works fine now.
Thanks,
Tom Cline
Bob M
05-09-2006 13:44:55
Tom - I cannot tell you if that part number is correct for an H. However if it fits in the brackets and the pulley fits on it should work.
Once installed the generator should be polarized to match the ground polarity of the tractor:
After all the wiring is hooked up (including the battery) and with the engine shut off, use a scrap of wire to momentarily jumper between the BAT and GEN terminals at the regulator. It only needs to be connected for an instant - and you may see a small spark when contact is made. You should then be good to go!
