value of a 350 utility
Frewheelin'
05-09-2006 16:07:40
Can anyone give me an approximate value for a 1957 350 Utility gasser. Good rubber, new paint, good tin, runs good, with a King Cutter mower. Any weak spots that I should look for. Asking price $3,750.
dhermesc
05-10-2006 06:31:47
 Re: value of a 350 utility in reply to Frewheelin', 05-09-2006 16:07:40
That might be a bit high, but if both the mower and tractor are in good shape it could easily be worth it. You could run the tires off your truck trying to find another one (at $3.00 a gallon to stop looking now might be real cheap). I've seen several utilties that were as rough as a cob go for $2000 or more just because they were running. You figure a new King cutter of any size is $700-$900.
PAULIH300
05-09-2006 18:02:18
If it has TA make sure it works.Check the water pump for leaks.Rebuilt 300/350 pumps are pricey! And the infamous steering.If it has any freeplay (like 1/2 a turn)the box is heavily worn and not easily fixed.If its power steering look for leaks out the pitman shafts and up thru the steering column.Any of these deficiencies...either walk away or dicker them down more than $1000 lower than they are asking.
CNKS
05-09-2006 17:06:35
Steering, if it ever had a loader on it. To me the price is $1000-$1500 too high, though. Don't let the paint fool you, will hide many defects.
Nebraska Cowman
05-09-2006 16:16:56
Don't sound bad. I've got that and more in Golden Boy
third party image
third party image
Even bad boys are just as good as they can be
jmauss
05-09-2006 19:46:54
 Re: value of a 350 utility in reply to Nebraska Cowman, 05-09-2006 16:16:56
Cowman! I didn't know you had the 350 Utility! I didn't see it in any of your family pictures, and I don't remember ever seeing it mentioned in any of your threads. I have only been a member for 6 months or so, but I look at this board every day. If you mentioned it before then, I would not have seen it.
What's with the yellow? Were some of them actually offered that way, or you just wanted a yellow tractor?
Always trying to learn more ..... ..... thanks.
Joe
PAULIH300
05-10-2006 02:34:32
 Re: value of a 350 utility in reply to jmauss, 05-09-2006 19:46:54
Thats actually a 330.Yellow was an industrial color,normally used by highway agencies...I guess for visibility reasons.
