966 Lug Bolts
Allan In NE
05-10-2006 05:42:59
Mornin' Guys,
Need to order some eyebolts so I can put the duals over on my 966.
What size are those lug bolts? 3/4" fine thread?
Darned things are kinda expensive, so don't wanna order the wrong ones. :>(
Thanks,
Allan
David A. Hodson
05-10-2006 15:49:17
 Re: 966 Lug Bolts in reply to Allan In NE, 05-10-2006 05:42:59
Allan, got the parts book in my lap. And its showing 3/4 in bolts washers and lock nuts. Hope this helps if you need anypart #'s let me know David
the tractor vet
05-10-2006 08:16:56
Word of caution here Allen on the 966 i would recomend direct axel mounts unless ya got wedge lock centers as once ya got over and 806 they had a bunch of problems with clamp on duals breaking out the clamps and clamp bolts along with the cast centers . I have enven broke two clamp bolts while having the duals on and i only run 10-12 lbs of air on the duals and 18 on the tractor . You would get more out of a set of direct axel mounts as far as traction and floation as then you can run the same air pressure on all .
calamazoo
05-11-2006 04:56:00
 Re: 966 Lug Bolts in reply to the tractor vet, 05-10-2006 08:16:56
Why are you running 10-12 psi in your duals. Tractor dealers, tire dealers and dual hardware manufacturers all recomend no more than 8 psi in duals and 6 is optimal. Our tire dealer told me that when a guy calls about anything that breaks on a tractor with duals his first comment is "too much pressure in the duals".
Allan In NE
05-10-2006 08:59:15
Hmmmm,
Yes, I've heard of that. However, here's what I'm thinking and here's my plan.
Let 'er bust. I'll tell the wife that it's gonna be awhile before I can find parts and the field work has to be done right now. So, in the meantime, maybe I should go out and find one of these little sweethearts? :>)
Allan
third party image
Steve KS
05-10-2006 14:16:54
 Re: 966 Lug Bolts in reply to Allan In NE, 05-10-2006 08:59:15
That"s what I call planning ahead! ;) But I thought the Mrs. had her heart set on a green one?
Allan In NE
05-10-2006 14:37:34
 Re: 966 Lug Bolts in reply to Steve KS, 05-10-2006 14:16:54
Yeah,
And she's not budgin' a bit either. Every time she sees me snoopin' around on ebay, she has to remind me that the next one WILL be green. :>)
Oh well, nice to dream, I guess. Trouble is, if and when we ever get the greener, I'm afraid that it's price tag is gonna rock her world. :>)
Allan
w gatewood
05-10-2006 06:16:39
allan, you are correct they are 3/4 fine thread
the tractor vet
05-10-2006 08:11:07
 Re: 966 Lug Bolts in reply to w gatewood, 05-10-2006 06:16:39
You sure on that i am thinking 5/8th fine but i could be wrong there 5/8th on the 806 takes a 15/16th socket and with out running out to john's place and checking his 966 his is also 5/8ths now that i think about it as he barrowed some of my extra DMI EYE BOLTS for his duals .
Allan In NE
05-10-2006 08:19:46
 Re: 966 Lug Bolts in reply to the tractor vet, 05-10-2006 08:11:07
Boy, don't think so, Vet.
They are either 3/4 or 7/8" rascals. Pretty darned sure that they are 3/4" things on the 966.
Never owned an 06 so cant say, but the little guys all take the smaller 5/8".
Seems to me this one takes a 1 1/8" wrench on the lug bolts.
Allan
the tractor vet
05-10-2006 08:28:32
 Re: 966 Lug Bolts in reply to Allan In NE, 05-10-2006 08:19:46
well it could be but i know that on John boy's 966 his are the 5/8th because when i got this 806 i had just aquired a set of 18.4x34 DMI clamp on duals with all the hardware and enough clamp bolts and eyebolts to put 8 on a side and since i am lazy i only put six on a side and had 4 extra 5/8th eyes layen around and john broke a couple and i gave him a couple to uses that now i am thinking about it he has not returned , going to have to have a long talk to the boy over barrowen stuff.
Allan In NE
05-10-2006 06:22:49
Thanks Pard,
I'm on my way. Like everything else, if I don't do it while I'm thinkin' about it, things usually don't get done around here 'til it's way too late. :>)
Allan
Harley
05-10-2006 23:20:10
 Re: 966 Lug Bolts in reply to Allan In NE, 05-10-2006 06:22:49
third party image
Hey buddy, try thisun on for size. Sure would lok good in that thing puttin up yer hay. Harley
