Cowman can you help me?
Paul Shuler
05-11-2006 12:40:11
Hi Cowman. I need help. I have a 48 H and the needle valve went to leaking. Pulled off the bottom of the carb and the old gasket came apart so to get the rest of the gasket apart I needed to pull out the venturi. Well it was stuck tight and when I went try and twist it a little it just fell apart. No one around here has one. This is my mowing tractor and the grass is getting high. It is the H carb with a single float. Smaller than the super H.If you don't have one do you have any ideas where I might get one?
Chris B.
05-12-2006 13:34:16
 Re: Cowman can you help me? in reply to Paul Shuler, 05-11-2006 12:40:11
There was a post here by a fellow who said his venturi fell apart also (with a little bit of help) and he reassembled the H carb minus a venturi and ran it with no problem. Might be worth a try just to get you by.
Chris B.
Farmer Bob
05-11-2006 15:39:58
Check your email Paul. Bob
Farmer Bob
05-11-2006 17:02:58
 Re: Cowman can you help me? in reply to Farmer Bob, 05-11-2006 15:39:58
Just sent you another one to that addy.
Bob
Paul Shuler
05-11-2006 16:42:21
I didn't find anything on my e-mail. You might try Pshuler@sprg.mercy.net
Thank you
Paul
neblinc
05-11-2006 13:03:07
I think Rusty Farmall rebuilds carbs, you might want to try and contact him.
Randy
RustyFarmall
05-11-2006 14:03:04
 Re: Cowman can you help me? in reply to neblinc, 05-11-2006 13:03:07
Yes, I do rebuild carbs, but I do not have a spare venturi. I do remember seeing an ad in a magazine awhile back, I think the magazine was Farm Collector, the ad was from Mark's Carburetors. He has brand new venturis for Hs and I think Ms. I do not have any contact information for him.
