i think im throwing in the towel
tn terry t
05-11-2006 15:38:14
i have spent a lot of money on this old h to put power steering and a loader on . i have nuthin but trouble ever since i put the steering part on
pump not big enough to do both so i get me another with double the flow rate and it ran backards well the vender took it back and swaped the innards now it run in the right direction but i tried it out and when i put a load on the #@$%#!@# blows fluid out from around the seal.I give up. shouldnt do that! if i am puting too much force against it shouldnt it quit pumping? i mean just quit moveing the clyinder and load the engine
tn terry
05-11-2006 18:36:16
 Re: i think im throwing in the towel in reply to tn terry t, 05-11-2006 15:38:14
well you know i might have figured out what is going otheway i have this thing rigged up is i made a adaptor to screw on the crank then i have a ujoint to kick it at an angle to miss the steering bolster7/8 shaft comes thru the hand crank hole i then have a 7/8 two bolt flange bearing to hold the shaft tru i think i forgot to tighten the bearing bolts down thus letting the shaft and pump shaft move during times od heavy loads. lets hope anyway i havent payed the vendor for the pump wont see him untill next week but if i ruint the seal i will pay him
tn terry t
05-11-2006 18:43:27
 Re: i think im throwing in the towel in reply to tn terry , 05-11-2006 18:36:16
third party image
trying a picture
Janicholson
05-12-2006 07:24:29
 Re: i think im throwing in the towel in reply to tn terry t, 05-11-2006 18:43:27
Many Hyd. pumps use casting passages to lubricate the pump bearings. These passages are (usually) from the non-pressure side of the pump, keeping full hyd pressure off of the seal. If the housing is for the opposite rotation, the pressure will be on the seal, blowing it out. Just my observation (I got into deep trouble with my father for 6 months when I was 9 for disassembling a new hyd pump for our sp125 combine. I spent 3 days putting it back together. All 6 months making good boy moves)
JimN
Allan In NE
05-11-2006 18:57:57
Terry,
Sure not trying to tell you your business 'er anything, but why not just get a live pump off a 300? Four bolts and she's on there.
Allan
third party image
tn terry t
05-11-2006 19:11:43
 Re: i think im throwing in the towel in reply to Allan In NE, 05-11-2006 18:57:57
cause im a hardheaded knothead Allen lol! you reckon 13.9 gpm @1800 will do the trick when and if i get the bugs workedout?
River Bottom Farmer
05-11-2006 17:37:46
If you quit now you will never get the joy of using you H just think a nice loader and that wonderful power steering,cant quit now.If you think back I bet youve worked twice as hard for something you wanted half as bad asthis.So come on fella keep pluggin youll get there.Its just around the bend..... RIVER BOTTOM FARMER
SDE
05-11-2006 16:00:46
Please don't give up. Take a step back. Give it a week if you can. Take someone fishing or golfing. Then get a second wind and try again. My opinion is that when we give up we are quitting on ourselves and that is an unfortunate thing to do. If someone else can do it, you can to. You just need to clear the cobwebs out of the brainbox and then you will be good to go again. Good Luck STEVE
Allan In NE
05-11-2006 15:59:09
I agree with Jim,
None of this is your fault, so don't get discouraged.
Allan
Janicholson
05-11-2006 15:45:28
Terry the ""vendor"" has made a mistake that entitles you to your money back. It was done twice, once with the wrong pump, and once with the wrong pump made wronger. Get the money and choose a different vendor for the pump. They are out there.
JimN
