International 300 front timing cover question
Jared Chaddock
05-11-2006 16:42:55
Another IH 300 question...To hold the front timing cover on, there are (6) 1/2-13 x 3 bolts and one stud with 1/2-13 on one end and 1/2-20 on the other for a nut. The problem is that, of course, when I took it apart, I didnt remember where the stud went. Does anyone know? Does it matter where it goes? I cant see any reason for it to go a certain place right off the bat, so I figured Id ask the experts. Thanks in advance.
Rick/Oasis ID
05-12-2006 07:08:03
 Re: International 300 front timing cover question in reply to Jared Chaddock, 05-11-2006 16:42:55
What motor do you have I have a 1956 300 with a c169 i just rebuilt. All the timing cover bolts were 1 to 1 1/2 inches long, none with nuts on them. there are a couple that come in from the rear through the hdy. pump that were longer but not the front cover nuts as you decribed
