240 Crankshaft
Darin in Nebras
05-12-2006 07:36:59
I might be replacing the crankshaft in my International 1961 gas 240 utility. Has anybody ever see any of these or have some good sites that might have some. I checked this site out and didn't find any cranks for it. I beleive is has the C-123 engine. I am not sure yet if I need cause I haven't taking the old one out yet and see if it can be turned. I would just like to know what I will be looking at spending if needed. Thanks for you time. Darin
gene bender
05-12-2006 16:34:58
 Re: 240 Crankshaft in reply to Darin in Nebraska, 05-12-2006 07:36:59
You can get one reground with bearings for 333.39 exchange so i would check with machine shop to see what yours would run reground and new bearings.
Darin in Nebraska
05-12-2006 12:01:47
I have had the main bearing caps off and the crank is kinda like an egg. I think that is my loss of oil pressure when the darn thing warms up. The rods where fine, but the mains have seen better days. Thanks for the post. Darin
El Toro
05-12-2006 13:05:49
 Re: 240 Crankshaft in reply to Darin in Nebraska, 05-12-2006 12:01:47
Here's web site for tractor salvage yards, some may be in your area. Hal
Link
Here's a web site with some good info.
www.lorenzomfg.com/parts.html
El Toro
05-12-2006 12:58:59
I would still pull it and have your machine shop
to check it. Hal
El Toro
05-12-2006 07:51:05
I would wait until you get the crankshaft removed and measured by your local auto machine shop. It may only need polishing. Even if it has been ground undersize, it may still require that same
size undersize bearings. Hal
Darin in Nebraska
05-14-2006 14:06:41
 Re: 240 Crankshaft in reply to El Toro, 05-12-2006 07:51:05
Thanks for the info bud, I'll check them out. And I will have the machine shop check it out first before I buy anything. Thanks again.
