M Carburetor Float Setting
Allen Edwards
05-12-2006 12:13:08
I went to my local Case-IH dealer for a carb kit. They sold me a needle/seat and bowl gasket and said that's all I need. The carb is in good shape so they may be right. However I have no instructions or specs regarding setting the float height and drop. Does anyone have those specs and where do I measure from? The carb is a 50983DC.
Brownie 45
05-13-2006 06:17:06
 Re: M Carburetor Float Setting in reply to Allen Edwards, 05-12-2006 12:13:08
A general rule of thumb is to hold the carb body upside down and adjust the float so that it is parallel to the carb body. Possibly a little less.[A lower gas level in the carb].
F-Dean
05-13-2006 10:26:18
 Re: M Carburetor Float Setting in reply to Brownie 45, 05-13-2006 06:17:06
According to my kit from OEM, it should be 1 & 5/16 inches at the outer-most part of the float. I turned the carb upside down and made the measurement. Then turned it right side up, make sure the needle valve was loose and then turned it upside down again and remeasured.
