tune up kit for 140 farmall
longhorn
05-12-2006 17:00:17
I am having a problem with the motor not running smooth, spit and spuders when you give it gas.but , it runs find when at an idle.Maybe something else.
El Toro
05-12-2006 17:12:42
 Re: tune up kit for 140 farmall in reply to longhorn , 05-12-2006 17:00:17
Are you sure its getting enough gas? Your carburetor may need cleaning and the fuel line, tank and sediment bowl. If these are ok, I would do a tuneup with new plugs, points and condenser.
You may want to recheck the valve lash too. If they call for.014"H set them at .017"C. Hal
