Replacing garder springs in Hydra-Touch control va
Jimer
05-12-2006 17:54:54
I took the Hydra-Touch control apart on my 300u and replaced O rings, gaskets, etc. I bought new garder springs (old ones were broke), but can not get them in for the life of me. Is there a tool, or trick, to do this?
Any suggestions will be appreciated. Thanks for reading.
Farmall Frank
05-12-2006 18:14:00
 Re: Replacing garder springs in Hydra-Touch contro in reply to Jimer, 05-12-2006 17:54:54
I made a "bullet" tool out of a piece of walnut. Used a lathe to make something shaped like a bullet, about 2" long, with a recess in the large end to place over the valve piece (forgot the name). I copied the look that was in a manual I got from Binder books that talked about hydraulic repair. Anyway, after two prototypes, I got one that worked. You place the bullet over the end of the valve piece, move the spring over the bullet, almost needing 3 hands to do it, and when the spring gets close to fully expanded, you slip the garter spring sleeve over the spring, and push the assembly over the retainer, put your tongue to the left of your mouth, and hope the spring and sleeve don't fly off across the room --- twice. Don't ask me how I know this.
It's tricky, but you need this bullet, in my opinion. And still, it isn't real easy.
I did 3 of them.
While you're at it, replace all of the o-rings.
Jimer
05-13-2006 09:59:47
 Re: Replacing garder springs in Hydra-Touch contro in reply to Farmall Frank, 05-12-2006 18:14:00
Thanks for the info, will try that. I did try something similar with a wood dowl pin but no luck.
Yea, I did replace all the O rings.
Thanks again
Farmall Frank
05-13-2006 18:48:44
 Re: Replacing garder springs in Hydra-Touch contro in reply to Jimer, 05-13-2006 09:59:47
third party image
Here's a picture, I hope.
